Full tower cooler than mid-tower?
Is it true that a full tower keeps internal temps lower than a mid-one?
false.
if your DAYAM good with cable management, a Small Form Factor can keep better internal temps then a full tower.
Its all about cable management, and proper fans.
yeah. The pressure will be easier to obtain within a mid-size case with regards to the strict cold-in and hot-out flow.
actually no..
in rules of thumb.. you get the larger case to compensate for your lack in cable management.
so if ur really horrible, a full tower is a better choice, because you have more room to make a birds nest, vs a small case, where it would be entirely filled with wires.
Yes that is somewhat right it all depends on what you have in case. The more stuff you have the larger the case you need.
KxK
Is there a guide somewhere about DAYM good cable management for optimal airflow/internal temp? Or can you provide one? This sounds interesting to me.
Thanks.
