Full FPS for a second than fan starts and low FPS
kiicki
14
So I get low FPS when playing games. for a second it will give me full FPS. Than the fan starts spinning and than it gives me low FPS again.
I would think that the low FPS comes first, and than the fan starts spinning, but in this case my low FPS starts after fan is spinning. It's like when I have perfect FPS for a second, and I hear my fan is going to turn up, I know it will give me low FPS right away.
Is this heat issue, or does the fan take to much power?
I have an Alienware M17x r3 with Nvidia 560M. CPU: Intel 2630QM
Is this throttling?
Highest temperature I get when benchmarking with Funmark is 85C.
Is it normal that I get low FPS AFTER the fan starts spinning?
I have ordered new thermal paste and it will come shortly. I just needed to know if it could be another problem. For me it was strange that the low FPS comes after the fan starts spinning.
I have cleaned all the dust, I just need to apply a new thermal paste.
Sims 4 works perfect. It gives me lag when changing city or something.
Techhog
2,834
Definitely throttling. Get a laptop cooling pad.
EDIT: Bench the CPU and GPU at the same time, and keep an eye on the speeds of both.
kiicki
14
EDIT: Bench the CPU too, and keep an eye on the speed.
I don't know about a cooling pad. it worked perfectly before, and with the same game. So I know that my laptop should handle this game without any problems. Right now I have my laptop on a book.
I will try thermal paste and dust again the fans. Is it something more I should clean? is it just cleaning the fans and apply thermal paste all? or do I tear up the whole laptop?
What software should I bench my CPU and my GPU with? I have already benched my GPU with funmark and my CPU with Prime 95
lyssword
5,630
25
yeah with older laptops the dust issue starts to add up, so I'd check cpu/gpu fan/heatsinks. Also, if you are playing with power cord on, try turning "power options" to "high performance", see if you notice the difference (make sure its not overheating I guess)
