Full cover water block for R9 295X2 (Vidoecardz)
3DVagabond
11,951
204
Well, if the stock solution and $1500 isn't enough for you, there's this...
Source: Videocardz
Needs a low profile bracket and you'll have the badassiest single slot solution around. :D
f1sherman
2,243
This has to be the best looking card. Ever!
So slick, you can tell it's ze founders of industrial design.
Techhog
2,834
Hopefully this would get well below 75C so it doesn't throttle. I really wonder why the ceiling on it is so low...
bleucharm28
495
Very very nice. But even nicer if is all nickel with blue dye. Even tho i don't like using dye myself. :)
3DVagabond
11,951
204
They're supposed to make a nickel version with a smoked plexi option for you less retro types. ;)
Kenmitch
8,505
2,250
It looks like a nice design.
Although it's not something you see all the time I too don't like the clear acrylic look.
thilanliyan
12,084
2,281
I really don't trust any acrylic components to put into a liquid cooled system. I've seen several components leak because cracks occur where things are screwed together. Can't tell from the pics whether the screws would be straining the acrylic though for this block.
