Well, I am going to second everyone's opinion that you should get this checked out as soon as reasonably possible. It sounds like a fuel leak. If you are reasonably handy, this is easy to diagnose yourself - find the fuel filter, which is usually in a reasonably accessible location. Now work forward and backwards from that. Pay extra attention to any fittings where rubber and metal lines come together. Looked for cracks in the fuel hoses, wet/damp spots, CLEAN spots, etc.
The best way to check is to turn your key to the "on" position a few times in the morning (but do not start) and then remove the key and go poke around under the hood. Turning the ign to "on" in many cars will pressurize the fuel system. (you'll hear the fuel pump running under the car for a second) A lot of times it is easiest to see a wet spot on a hose or whatnot rather than sniff your way around. You may simply need to go around tightening all the fuel line clamps with a screwdriver and you'll be good to go.
Just becuase you have a fuel leak does not mean that your car is in emminent danger of blowing up or anything like that - but there is obviously some potential danger there and yes you should check it out. I wouldn't smoke while I was doing the checking out though. 🙂
PS: It is not unreasoanble for a 92 car to be developing cracked fuel lines... this falls into the category of general maintenance because it's just plain old. 🙂
