Fuel injector cleaner
Chevron Techron. Make sure you get the bottle that says "Chevron Techron". The other lines of Chevron fuel injectors saying "contains techron" are weaker versions.
You can get a 4 pack at Costco for pretty cheap. (The Chevon Techron version)
BG44K is very good, but you'll have to call around to find it, usually only NAPA carries it. I do believe that they do something, but there are alot of snake oils out there so it's easy to be suspicious.
Originally posted by: richardycc
BG44k (~$16-20) is the best, following by redline ($5) one that you can get from pepboys.
beware! the new formulation of BG44k is not like the old stuff. Text
Text here was a previous thread about injector cleaners. There is some good info and links to compositions of fuel system cleaners.
I used a bottle of some pricey (10 bucks) stuff, and my car seems to be a little quicker with the response, nothing much more tho.
You can get 3 or 4 (Can't remember) bottles of Chevron Techron for $10 at Costco. Chevron Techron is pretty good.
The stuff they sell at costco [at least near me] is "proguard," not the chevron techron complete. The techron complete is much stronger than the proguard stuff. They both contain techron however.
Originally posted by: SampSon
Originally posted by: Aimster
A study by consumer reports found that they don't do anything.. but any of them should be fine.
Please back that up.
Aimster made a similar claim in the thread I linked to above, and has yet to back his claim.
If they don't "do anything" then why is its use (injector cleaner) endorsed by major auto manufacturers, and how come I see actual results when I use the products?
