I had Red Hat 7.1 install on one of my machines. It was a little messed up and wasn't working properly so i decided I was gonna reformat and either install Mandrake 8 or go back to 98. I used a 98 boot disk to get to FDISK and delete the partitions but can't do it. I had a small, 16 MB partiton using linux native that was easily deleted, but then i have a 1 gig extended DOS partition that can't be deleted because it claims there is/are logical partitions inside that extended partition. If this is the case, FDISK can't see the logical partitions so i can't delete them, thus can't delete the extended partition. I've tried getting low level format software to hopeful solve this problem but haven't found any that will work. The drive is made by seagate, so other manufacturers diagnostic tools won't work (I've tried). I'm sure seagate puts out software to do what i want, but I can't seem to find it. I've tried disc wizard, but that just seems to test the drive. I've also tried seatools, but that's strictly windows based. Any help would be greatly appreciated...
