FTP issue
QueBert
I host with hostpc.com I have 2 domains with them, when I connect with Filezilla I'm not seeing a /domains directory where I can go in and select the domain directory. I'm trying to edit a php file but am confused why in the file manager of Direct Admin I'm seeing /domains/domainname but in Filezilla I'm not. Any ideas here?
Every domain ive ever done has always had its own separate login/connection. Are you sure you are supposed to be able to see both with the one connection in the same root directory? Typically each domain should have its own connection and its own root.
