- Jan 11, 2001
- 28,830
- 17
- 81
System setup:
MSI Neo2-FR Motherboard rev 1.0, v1.6 Bios
Cooler Master Vortex TX Cooler (27c idle, 47c loaded temps)
E6550 CPU
Xclio 450BL PSU
2x1GB OCZ Platinum PC2-6400 Ram
My best max OC so far has been 2800Mhz @ 400fsb. It's 100% stable no matter what I throw at it so no real complaints there.
http://img508.imageshack.us/img508/251/babyoc2pw9.jpg
My question is, no matter what I try to go higher, it will not boot AT ALL. It won't even ty to load windows. I'm wondering if it's the mobo or maybe the ram holding me back. No matter what tricks I try to isolate the issue, it will not go past 400fsb! Everything runs at stock volts and bumping voltage on any or all helps none. I've relaxed the timings on the ram, lowered the multi on the CPU, nothing.
I tried setting the bootstrap via jumper to 200mhz down from 333 and 266 and it helped none. I tried 433fsb x 6 and it refuses to post. Anything between 400 and 433 it sometimes posts but won't boot into OS. It seems something has a 400 ceiling and I can't figure out what it is. I don't have many divider options for ram on this mobo so i'm not sure where to go next. No matter what tweaks I try, it seems that it refuses to go 1 tick over 400fsb.
E6550 CPU
Xclio 450BL PSU
