FSB Speed and PC133 Ram question
Mota
Hi there,
I just started building my system, and have 256 MB PC133 SDRAM.
M/B is Asus A7V133 (KT133A)
I've installed an Athlon 900 right now, but not sure if that's the right choice.
With PC133 Ram, is there a performance difference between a 200mhz FSB and a 266mhz FSB?
Is it worth getting a 266? I'm seriously considering getting the 1ghz C model, but I want to make sure it's worth it for the trouble it'll be of installing a new CPU into my system.
you have totally no problem with running a tbird 'c' on your mobo
but almost all 200 tbird will do 266 if you oc it
it depends if you want to oc or not
why waste mmoney to get a 'c' tbird
