Originally posted by: RichUK
Originally posted by: hardwareking
thanks for the replies.And i think i truly understand now.
So is this the reason K8 was whooping netburst like there's no tomorrow?
No thats just partially the reason, the Hypertransport and the FSB models are just part of the processor subsystem, basically a means for processor communication.
The difference in architecture denoted the best performer (K8 Vs Netburst). If you notice Conroe (new arch), this still uses the same processor communication model (the FSB for all communication) and beats the K8 arch in pretty much all performance tests, this is down to a better design. Of course the addition of 65nm and more and unified level 2 cache aids in its better performance too, but this just simply proves that the FSB is not a hindrance yet for Intel?s subsystem.
Back then AMD's K8 was just simply a better design overall over Intel's Netburst design, they took different roots in designing the better performing chip.
AMD took the root of a high IPC with moderate frequency design, where as Intel had a lower IPC but a higher frequency design, the problem was a number of things that held net burst back, where the main issue was the heat that was generated. If not for this Netburst could quite well of scaled a lot further and surpassed AMD's K8. In the end Intel were only able to produce a retail 3.8Ghz model as its fastest brand based on the Prescott Netburst design.
