Frying Power Supplies
Kilau
I had to do a partial rebuild on a my computer due to some unknown reason it had stopped booting. I purchased a GA-K8NS pro motherboard, a AMD 64 3400+ and a new case with 450W Power Supply. After moving my video card (Geforce 4 Ti4600) my hard drive, cd-rom and memory (512MB stick DDR333). I set about installing windows xp again. After about 2-3 hours of the system running fine and finally getting all the windows updates (minus sp2) and installing drivers I was ready to play some Everquest.
45 mins into the game the machine died with a loud pop and an acrid smell, I thought super I got a bad CPU but realized it was my 450W power supply that died...so I threw in my old 300W power supply the machine worked fine and I loaded up Everquest again...5 mins later that power supply dies. On my 3rd power supply now a 350W from Best Buy and haven't run a game yet but I have updated the bios and I am using the system right now. I don't want to keep blowing out any power supply I put in here but I can't figure out what the heck is going on here.
The only odd thing I can see is that the boot screen says the CPU clock frequency is 200MHz, which should say something like 2.4Ghz I would think. Really could use some help here, I don't have tons of cash to throw at replacement parts and would very much like to have a working machine again.
Thank you.
Smilin
7,357
Bad power out the wall?
FYI that cpu clock freqency is probably right. That's the front side bus frequency and the cpu runs off a multiplier of that (12x in your case).
Kilau
Yeah the power supplies are always set to 115V, the wall outlet should be fine. It has been fine for a long time now and everything is pluged into a surge protector, nothing else is blowing.
The system will run fine in Windows, this only seems to happen when its under a load, like playing a game. :(
Thanks Smilin for helping me understand the multiplier deal, not used to seeing it presented that way. 12x200 = 2.4Ghz :)
