A properly install cable line would not hit your computer
If the cable is properly grounded to your electric meter or to any ground rod, it'll go there and get absorbed. If you dont have a ground block on ur meter pipe which should goto the ground rod, ur screwed. Also electric travels shortest distance in a Y pipe, ie, ur ground wire is longer to the ground rod than ur computer..
ie. ur computer is right by the ground block, your ground rod is on the other side of the house... ur computer fries before it gets absorbed.
Get an ups if ur in a heavy thunder storm area..
