JulesMaximus
I have a Windows 7 machine I built a couple years ago. It is an i7 Quad Core system with 8GB RAM and an MSI P55-GD55 motherboard with onboard LAN. I've been using this computer for years now with no trouble but last week it stopped connecting to my network. The connection monitor shows a red X and it says either no network detected or if I open network manager it says there is no networking device installed.
At first I thought I might have a virus because I've made no changes to this system recently but that was not the case. I've tried swapping out the network cable, plugging it in to different ports on the router, I've reset the router and cable modem, I've tried reinstalling windows, I went out and purchased a new NIC and installed it along with the drivers (yes, I did disable the onboard LAN in the bios before I did this) but same results. Every other computer in the house connects fine except this one.
Odd thing is that if I open device manager there is no network device listed but if I click view and click show hidden devices it appears and it appears to be working, even though it doesn't. There are no hardware conflicts or devices that aren't installed correctly that I can see.
I'm not sure what more I can do at this point... 😕
Any suggestions?
Update: Changing to a different PCI slot worked. Not sure why but I'm back up and running.
Thanks for all the suggestions.
Any suggestions?
