hi,
I have a coil whine issue in my rig which is very frustrating
(with headphones we hear much better on my speakers i can't hear it and I assure you it's audible IRL)
I had read that this kind of coil whine is not dangerous for the devices , whether it is the power supply or the graphics card, could you confirm it to me.
What is weird is that the noise occurs at + 30FPS +, i've limited FPS to find out it does not occurs only at high fps as i was used to with coil whining GPU... I try to play with the sliders of MSI afterburner and I can hear that the sound changes .
After that I only hear it if the fans are at their lowest and the panel is open so if it is certain that it cannot harm my configuration, it is not very serious but I would like to be sure.
However I would like to understand because the problem arises with:
it's driving me crazy mostly because I don't understand WHY
I've ordered a HX 850PSU by corsair and hope it will fix the issue.. Is there a chance it will?
Thanks for your help
- 2 different graphics cards (EVGA FTW3 2080ti and Asus Strix 2080ti Oc that someone gave me for test purposes). The two cards do not make this noise in another config
- 2 power supplies of the same model (Seasonic Ultra Prime titanium 850w)
- 2 motherboards of the same model. Asus Maximus Hero XI
- Cstate on and off
- Mod cable cables or original cable
- Tried other cables sent by seasonic
- trieds ferrites on the cables
