Actually Supergroove, AWD is the perfect way to go for nuetral handling, you can just keep powering into the corner. Especially those cars with automatic torque bias. Such as Skyline GTRs, where by default they are set at about 65% torque at the back & 35% at the front, where they are also setup to redirect torque away from whatever wheel is losing grip to the other wheels. That's one of the main reasons that the GTR dominated Group A' Touring Car racing too such as extent that FIA replaced Group A with the '2 Litre Touring Class' (such as BTCC) as the premier touring car class.
Hence virtually all the top performance car makers make such AWD drive cars (either using electronics or viscous clutches or other technics). From the original Jenson Interceptor MKIII 'FF' of the early 70's, which used a AWD setup that was initially designed for agricultural equipment to such vehicles as the Subaru WRX & Porsche 959 & Carrera. Even the Top Lambigini is AWD now.
I preferr RWD over FWD anyday, once one is experianced in the limitations of a car, & knows what they are doing, RWD is much better at taking to the limit. RWD is also better for working on.
