Frontpage and hit counter question
darkcyber
167
For some unknown reason my counter will get screwed up on my web site and instead of showing the counting numbers it shows the words 'Hit Counter'. I have to go into Frontpage 2003 and redo the counter and once I do that I loose all of my previous hits, it resets it back to zero. Even if I check the box that says 'reset counter to' and then enter a number, it never shows that number, it continues from zero.
How can I edit my hit counter to change the hits back to what it should be?
Thanks!
