Hi all,
I have a university account that allows space for personal web pages. The accounts they give us are Unix shell accounts. They instruct us to put everything into a directory called ~/public_html within our home directory. BTW, the university does NOT support FrontPage extensions. Is there an easy way so that I can "publish" my webs using frontpage to my university public_html folder??
I know I can manually ftp everything myself, but I want to be able to make changes often, and using "publish" is much simpler. I've tried doing the following:
1) File -> Publish Web -> Publish destination = ftp://www.duke.edu/~myusername/public_html. When doing this, I get an error stating "The FTP session was terminated"
2) Start -> Programs -> My Network Places. I then create a network place called ftp://myusername@godzilla.acpub.duke.edu/public_html.
I then get prompted to create a web at this location because its empty, and then when it goes to connect I get an error that says "Could not find a webserver at myusername@godzilla.acpub.duke.edu. Please make sure that the webserver name is valid and your proxy settings are set correctly. If you are sure everything is correct, the webserver may be out of order temporarily".
3) I tried creating a network place that hard-coded my path into the ftp URL. IE, the network place was called:
ftp://godzilla.acpub.duke.edu/afs/users/var/myusername/public_html. After trying this, I got the same error above in # 2.
What am I doing wrong? Is there an easy way to get FrontPage to work with my school's FTP server???
I'm running WinXP Pro with FrontPage 2002. University account is a unix csh account. Any help appreciated.
