"Front USB" vs "Front USB 2.0"?
cmai
144
Can I replace the cables of case to make it support Front USB 2.0?
Thanks,
cmai
thorin
Only if what you're attaching the other end (the internal mobo/controller connection) of the cable to is a USB2.0 compliant.
Thorin
cmai
144
Yep of course. =) But I want my front usb to use 2.0 speeds. So if the advertised case says "Front USB" instead of "Front USB 2.0" then can I still use it?
Mitzi
3,775
Thanks,
cmai
Don't cross post. :evil:
Edit: IIRC all USB ports and cables are the same, its the controller which dictates if they are USB2.0 or otherwise.
thorin
Thanks,
cmai
OMG what a noob......
That's my understanding as well.
Thorin
joeryu
1,678
thats what i thought, but it wasnt the case on my antec pp1080 front ports. my mobo supported usb2.0 but whenever i plugged in a usb 2.0 device to my front ports they only worked at 1.1 speeds. i emailed antec and they shipped me a new usb 2.0 compliant front ports, and now everything works fine~
thorin
Wow learn something everyday.
Thorin
Lyfer
5,842
Thorin
Amazing:).
