Sometimes the case has a place for the Audio jacks/wires but they are optional. I would be surprised to find the actual jacks present but with no wires. You may be able to find something you can use at: http://www.frontx.com . Also look at your case mfr's web site. You can often buy the optional jacks and cables from them. All else fails, get a 3 foot stereo (headphones) and a 3 foot mono (mic) audio cable from Radio Schlock and hot glue them in place...
.bh.
check the www.frontx.com site for internal connectors....and then check out www.cyberguys for internal connectors...you should be able to find them there.
