- Dec 3, 2002
- 3,763
- 0
- 0
I've noticed at work and at home that sometimes when a USB pen drive or watch drive is plugged into the front (not back) usb ports of some PCs it won't work with it correctly. Out of about a half dozen systems, several have worked fine with a usb storage device plugged into the front USB and several (including my personal system) have not.
Does this have to do with differences in the motherboards themselves as to how they support front USB, my own error in wiring the front USB, a software problem, or something else?
I've seen both XP and 2000 both work and not work. I've tested multiple pen drives people had and my own USB storage watch so it's not the USB storage device itself. Other USB devices (like mice) will work fine in the same front USB ports that aren't working with USB storage.
Here is the specific error on my win 2000 machine upon hooking up to the front USB:
Completed the Found New Hardware Wizard
USB
An error occured during the installation of the device.
The installation failed because a function driver was not specified for this device instance.
To close the Wizard, click Finish.
Again, works just fine on the rear USB ports of the same system.
USB
