Hey,
I was just wondering if there was any place you could buy generic front USB ports for a case. I got my case used from somebody, so I don't know the manufacturer. The USB ports look like the ones you find soldered to the motherboard's back panel, but instead of being soldered down, there are wires coming out of the bottom that go to the connector. So, in short, the part I need to replace is simply a small metal box (two USB ports stacked one on top of the other) with wires coming out of the bottom.
I spent quite a bit of time on Google and Newegg.com without any results. Maybe I wasn't searching right, but I couldn't find anything.
Thanks,
-~Chris
Thanks,
-~Chris
