Front tire causing vibration?
se7en
2,303
My wife took my car to get it inspected yesterday and they told her I needed a new tire so they replcaed my front drivers side tire. There was still a 1/4 inch tread left but w/e im fine with paying for it.
Anway on the way to work this morning I noticed the steering wheel start to vibrate around 65mph but I didnt notice it at lower speeds. And now theres a ticking kinda sound when I cruise between 30-45mph but doesnt make any sound at higher / lower speeds. I popped the center cap off / inspected tire when I got here but didnt see any noticeable obstruction.
My only 2 guesses would be either I need to replace the other front tire as well for some reason or they didn't balance the wheel when they put it on? Any ideas? I didnt think to check the tire size they put on so I guess a mismatched tire might be the cause?
Thanks in advance.
woodie1
5,947
If the car didn't vibrate before the tire was replaced then I'd suspect that the new one isn't properly balanced.
EDIT: Forgot to mention that they may have used an air wrench to tighten the lugs which could have over torqued the lug nuts and bent the rim.
boomerang
18,883
641
I agree with the other two posters. Check to make sure they're the same size as you said.
I wouldn't have one old and one new tire on the drive wheels anyway. Rotate them to the back. I'm making as assumption it's FWD.
Acually, I'd get a matching new tire as you've already thought.
