Front projector question?
Mathlete
652
Is there anyway (software) to get my cheap front projector to be set up to rear project. I can sort of get it working with a mirror but I am looking for a better solution.
Any help would be appreciated.
The-Noid
3,117
4
Software would be built into the firmware. No really easy way to get it working without it being built in for calibration.
sivart
1,786
Most modern (I.e. less than 10 years old) projectors should have a setting for rear projection. How old is your projector?
sdifox
101,209
18,220
define setup. Are you just talking about flipping images or actual geometric adjustment?
Mathlete
652
Projector = 12+ yrs old. Got it for $50 and the lamp works.
Just want to flip the image.
monkey333
785
That's amazing a pj that old does not have a placement menu.
Ie front, front upside down, back, back upside down..
