ChAoTiCpInOy
Maximum of $3000. Have no idea what to look for. Lots of help needed.
How big is your screen?
Do you plan on using an anamorphic lens?
The Panasonic PT-AE4000u and Epson PowerLite 8500UB are both great choices in this price range.
Let's go for a 100" screen?
As opposed to a?
I have a 100" 1.3 gain grey screen and the 8500UB. It's a nice combo. Definitely brighter than the AE4000, so it'll be less of an issue as the bulb ages (brightness drop off). It's even usable with a good amount of ambient light.
The drawback of the 8500UB is you can't really use an anamorphic lens with it, since it doesn't have the stretch mode without an external scaler. To be fair, who is going to spend $2k on a projector and twice that on a lens though?
Apex, is your 8500UB as yellow/green as these screenshots show?
http://www.hometheaterpeople.com/projector-showroom/projector-video-demos.asp (select Panny 4000U for one and Epson 8500 for the other and you'll see the difference)
Or this
http://www.projectorreviews.com/projectors/PT-AE4000_vs_Epson_HC8500UB/8500UB_vs_PT-AE4000.php. Art says his 8500 doesn't look as green as those pics
Panny on left, Epson on right
http://www.projectorreviews.com/ima...000_vs_8500UB_galaxyquest_commander_large.jpg
http://www.projectorreviews.com/ima..._8500UB_5thelement_leeloo_contrast2_large.jpg
The Epson seems considerably more green/yellowish and I like the image of the Panny better. But I do prefer the higher brightness of the Epson (Art claims the Epson is nearly 40% brighter)
With the prices being only $100 of each other now, the Epson is certainly a contender for me. Also 8500's bulb is cheaper and lasts longer than the 4000U. So if I can get the Epson's image more like that of the Panasonic's, I think I'll go the Epson route over the Panny.
make sure to keep some money in your budget for a real calibration. !! Will make a decent projo look fantastic. Or a fantastic projo look even better.
Also, the OP needs to put money aside for a replacement bulb. My PJ's replacement bulb cost $400.
How often do you have to replace the bulbs?
