I bought a new Antec Solo case to move my wife?s old Dell 4300s into. I?m having a problem with the front panel connections and getting the machine to turn on and off.
Pic 1
The old Dell case used a non-standard USB/power ribbon cable from the mobo to connect to a PCB board with another cable to connect to the front panel.
Pic 2
This configuration allows the machine to turn on when I plug in the power cable. I am not able to reset or power off using the Antec's front panel buttons.
Pic 3
So my question is, does anyone know the pin configurations and how to correctly connect the Antec solo's power switch (blue/white cable) and reset switch (green/white cable) so I can properly reset and turn the computer on and off?
Pic 1
Pic 2
Pic 3
