Front Panel Connections MSI RS480M2-IL
stimpy1
1.) I have two wires, one with a + (lime green color) and one with a - (white color). They are not labeled by the case manufacturer and the only place they could fit are two connector slots marked "MSG LED pull-up" in the motherboard manual. That's where I plugged the wires in. Any other ideas?
2.) There doesn't appear to be a place to plug the front pannel speaker wire in that I can find, and it isn't marked in the motherboard manual or on the motherboard itself.
Originally posted by: xsilver
I thought lime green/white was for "power led"..... have you got that already?
You're right.....I've got the green plugged in on the left in the slot marke "p" ( slot 2)and the white on the right in the slot marked "s" (slot 4). Is that correct?
Still no idea on the front panel speaker wire.
you're right when the pwr led comes on!!!! unless you buy a major brand case the labeling can be really crappy
speaker wire should be red/black
Well, i fired her up and she works fine. Everything looks good in BIOS (processor correctly identified, identifyting 1 gig of ram in dual channel). Now I just have to install Windows 2000.
Oh, i also got the classic beeeeepppp!!! at startup, so I guess I don't need that audio connector plugged in.
