Merry Christmas!!
I'm really confused on how to hook up the Front Panel Audio, Firewire ports, and USB ports on the TT Tsunami Case (for the front panel). I have an Epox 9NPA+ Ultra Mobo.
1. For USB, my manual says that I need a "NC" connection on pin 10. Currently, I have a cable labeled "Sheild1" in that spot, as it is the only spot that makes sense. Is this right?
2. For the audio, I don't have a wire that has "NC" connection, but the only one available is a wire labeled "MIC VCC". Is this the right one?
3. For the IEE 1394a, I need 2 +12V (fused) connections, and 2 ground wires, but I do have 4 wires, 2 of which are labeled "VG", and the other 2 are "VC". I also have one other wire labeled "ground". What do I do with these?
Can anyone point me in the right direction?
Thanks
Thanks
