I have an Antec Sonata case (http://www.antec-inc.com/pdf/manuals/Sonata_en.pdf). I have the Asus K8V SE Deluxe. I want to enable the Firewire port at the front of the case. There is a cable from the front of the Sonata with the following labelled wires:
VP
VG
TPA+
TPA-
TPB+
TPB-
The Asus board has a 10-pin connector for the bundled Firewire module. I'm assuming I can wire the cable from the case to this.
Looking from left to right (2 rows of 5) the pinouts are labelled as follows:
Top row: TPA0- GND TPB0- +12V GND
Bottom: TPA0+ GND TPB0+ +12V [blank]
First of all, can I enable the front port in this way? If yes, then I assume I plug the TPA and TPB +/- connectors into the similarly-named connections on the motherboard. After that I'm stumped. Has anybody tried this before? Or is it obvious to someone with more knowledge than me? (that's not difficult)
Thanks
Martin
VP
VG
TPA+
TPA-
TPB+
TPB-
Thanks
Martin
