Front case LED to read 66. How?
Drifter
270
>Can anyone please tell me how to set my LED at the front of case to read 66. It now reads 40
>Have a 486 DX 66
>Thanks in advance.
Hender
647
Maybe is your turbo button not pressed? I remember how the old 486's had a turbo button on them that would slow the system down for older apps, so maybe that'll do the trick.
nightowl
1,935
Usually there is a set of jumpers on the bacl of the LED that will allow you to pick which parts of the "8" will appear to make the 66 that you want. You will probably will have to play around with the jumpers to find which one illuminates the individual part of the "8".
Drifter
270
Hender>Tried that already and nothing happens.On boot up the monitor shows 66mhz.
crypticlogin
4,047
As an alternative to the turbo button, CTRL-ALT-"+" should do the same thing in DOS. I don't know what you're running, though.
Topochicho
338
nightowl has it correct, but there are actually 2 setting, one with turbo on and one with it off.
