front audio jack help
zonkie
113
I recently built a new pc and the case has front audio jacks. My MB has a place to connect it but I am assuming that is for the onboard audio. I am using an Audigy card. So how do I connec the front jacks to my soundcard?
natto fire
7,117
10
Look for headers similar to the ones on the mobo, on the soundcard. A lot of times they have aux in, with a connector. You could use this if you modified the case connectors to fit the jack. Not sure about the audio out, it would have to have the headers to connect the case connectors.
