Front Audio Connections
ryanj
I have been trying to get my front audio ports to work for weeks with no luck.
The pins on my motherboard are labelled like this:
1 PORT1_L
2 AUD_GND
3 PORT1_R
4 PRECENCE_J
5 PORT2_R
6 SENSE1_RETURN
7 SENSE_SEND
8 Empty
9 PORT2_L
10 SENSE2_RETURN
The wires from the case are labelled like this:
R-OUT
R-RET
L-OUT
L-RET
GROUND
MIC-INT
MIC-POWER
GROUND
I cannot figure out what to plug into what. There is one audio out port and one mic port. Any suggestions would be greatly appreciated.
Harvey
Administrator<br>Elite Member
67
What is your motherboard? Check the manual and/or the manufacturer's site. Some boards require you to move one or more jumpers to enable front panel audio ports.
If that's not the case, I would guess that these are the associations you need for the outputs:
1 PORT1_L = L-OUT
2 AUD_GND = GROUND
3 PORT1_R = R-OUT
4 PRECENCE_J = ???
5 PORT2_R = (Ignore - You have only one set of audio outputs)
9 PORT2_L = (Ignore - You have only one set of audio outputs)
I have no idea what the input labels mean. You should find that in the manual. It COULD mean:
6 SENSE1_RETURN = MIC-INT or L Audio input (guessing INT means Input signal and it's the Left channel of a stereo input)
7 SENSE_SEND = MIC-POWER
8 Empty
10 SENSE2_RETURN = R Audio input.
Hope that helps. Good luck. :)
