ManBearPig
It seems split 50/50 that people think front should be intake and rear exhaust. anyone wanna shed some light on this?
Originally posted by: VinDSL
Sorry for being ambiguous, but whatever works for you is best...
That's probably why opinions are split on this topic!
I have a friend that builds computers (small business -- 5 employees) and he swears top exhaust is best... 😀
Originally posted by: Zepper
"Warm air rising irrelevant..." Well, if that is the case, why not put the exhaust fan straight across from the intake fan at the bottom of the case?
2. The CPU must be situated near an exhaust fan, so that the hot air coming off the CPU cooler exists from the case rather than re-circulating.
I'd bet you'd get at least a 5 deg C rise in case temps. But it would be hard to test as no case maker that I know of does it that way for some strange reason... :roll:
Originally posted by: yiranhu
Heat rising in general is irrelevant. Your fan moves the warm air out before it has the chance to rise. Think of fire place... it takes very long for you to feel the heat generated by that fire. If you build a fire outdoors with wind, you have to put your hand very close to the fire to even feel the heat.
The only reason why the rear exhaust is on the top is because the CPU and PS and other heat generating machinery are on the top. It would actually be better if the front intake fans are on the top. Then you have a straight line of air movement from front over the CPU and out the back. Unfortunately the top is usually inhabited by DVD/HD and so on. So we compromise by putting a fan on the bottom.
