from seagate 7200.7 160gb to 7200.12 500gb speed noticable?
smellyfungus
hello i searched from this but couldnt find anything specific.
i got a coupon from staples for 15 off 25 or more purchase and was thinking about getting a low costing new hard drive for a little extra space and speed boost. the seagate would cost 40 without taxes.
i couldnt figure out how much real world difference there would be or if i would notice at all.
i looked at old reviews and the 7200.7 160gb i have had a read avg of 44mb while the 7200.12 500gb read avg was around 105mb
it sounded a lot faster but i wanted to make sure i wasnt wasting cash unnecessarily.
i use my pc for watching hi def files, general computer use and pc games like cs:s and sc2.
also my specs are 3800x2, 2gb ddr400, 7800gt if it matters.
thanks for your time.
for $40, sure will. Your HD is the slowest part of your system, well unless you spend all day working with thumb drives, but it should be a noticeable change.
7200.12 has extra cache the 250gb model doesn't this helps a bit. i'd save my money for ssd - honestly.
You will notice a massive upgrade in boot time and system speed from a 7200.7 160GB to a 7200.12. I recently upgraded a client's 7200.9 160GB (single platter drive - about 75% faster than your drive) to a 7200.12 and the 7200.12 is noticeably faster.
As for the cache on the 250GB and 500GB versions, it really doesn't make that much of a difference. The main thing is you're going from a two-platter 160GB drive to a single-platter 500GB drive, which accounts for the massive transfer speed difference.
16meg of cache does make a difference. benchmarked - most certainly does. doesn't hurt to use both sides of the platter to increase read/write as well 🙂
