- Apr 7, 2003
- 4,278
- 0
- 0
I'm working on the exact design in my favorite program(paint) so I'll get an image up ASAP but, here's the general idea. It will be a one on top of the other design with the cold side of the air conditoner on the intake in the bottom chamber and the hot side on the exhaust at the top. I've already dis-assembled a spare window A/C unit I had sitting in storage to get all the measurements and make sure it worked well. The cold side frosted over in ~2 minutes with the fan taken off the cold side but, still operating on the warm side. I also disabled the fan motor all together and the cold side took about 7 minutes to frost over and the warm side was warm to the touch but, not warm enough to do anything really, not even warm enough to keep the cats from sticking their noses on it to figure it out. Testing with the stock fan it's going to take about 400cfm to keep the cool side from frosting over on it's lowest setting. The A/C unit I dis-assembled has an integrated temperature monitoring and control system, though not digital I have a couple of VERY acurate temp probes I can use to map out the analog switch's activation and shut off temps in a couple spots. I also have an identical second one for spare parts if it comes to that. I was really impressed with the fan and motor on the warm side and I may just steal the fan off the warm side of the second unit for my intake. The fan that came on the cool side of the unit moves probably near 800CFM or more but, it's helaciously noisy and it's designed to pull through the condenser and output to the sides or top so that probably wouldn't work well in my application without some heavy modifications or an overly complicated design.
Any thoughts?
First Paint sketch of idea from 3 angles.
Let me offer a little insight into the reasoning here. It can easily be explained with one very short sentance. I live in Arizona. It's so damn hot here I have to give my computers their own air conditioners. I'm only really hoping to get this done before summer gets here and i have to choose between HUNDREDS of dollars a month cooling the entire house by 50 degrees or give the computers their own A/C. Right now I have the window open with the nose of my computer sticking out and my ambients in the middle of the day are still in the 50's-60's. At night I get to have fun though. It's been getting below freezing.
EDIT/UPDATE:
After doing a lot of research I feel a lot more comfortable modifying the coolant loop. My original design was made attempting to preserve, intact, the loop exactly as I removed it from the AC unit. This was for two reasons. Primarily I was quite un-familiar with the inerworkings of HVAC stuff and still am, just not quite as much, and secondarily because it was working fine and why fix what's not broken. My main problem and main reason for changing my mind was airflow. This is still going to be an air-cooled case with air cooled components so air-flow is a key. I've never built an air-cooling case without hooking up my fog machine and very thouroughly testing the flow. From doing that more times than i'd like to count I know a bit about how air likes to act and doesn't like to act. I'd have to say it's flow is about halfway between how water flows and how light flows, it can be made to make corners but, not without a lot more disturbance than water. My previous design was horrble for airflow, I tried to draw and balance it as best I could with some rear fans but, it was just going to be sh!t no matter how I played with it.
Well I was at work this morning just stewing over it and something I had thought of a while ago when it hit me. I could save a ton of space, better the airflow, centralize the main heat sources and passively cool the condensor. Want to know how? I get off work in half an hour, will be in paint in an hour and it'll be up by 11m mountian time. (dun-dun-dun)
Any thoughts?
EDIT/UPDATE:
