From Chile & UnknownTeam.cl: DICE, 930, 875K, 655K & "WR on Air" Inside!
clockero-ut
Hey Guys, this results are from the review recently posted on our web..
sorry for my english, but the pictures talks anything :awe:
For SP 1 and 2MB pull down the freqs. for stability and temp.
Btw, good work for a noctua u12p :D
For people interested, {edited out} (warn: only spanish)
Linking to your own site is spamming, and not allowed here.
Markfw900
Anandtech Moderator
Soon we post a video running the system @ +5ghz on air :D
Regards from chile
StrangerGuy
8,443
124
Clarkdale really flies once you can take the integrated PCIE controller out of the OCing equation huh?
faxon
2,109
snap yo! those dual cores really can clock cant they. almost has me looking forward to sandy bridge, that's probably when im gonna be upgrading to whenever i upgrade this system. sandy bridge quads should probably be clocking like that on water by then, and i love my cores, lets me load balance more DC apps at once :D
DrMrLordX
23,233
13,325
Wouldn't want to run a 32nm chip at those voltages for too long, but hey, nice OC.
clockero-ut
probably, this night we take a video from the system running at +5ghz on air.. Santiago it´s a cold city at this time (0~3 °C lowest temps) and help us :D
And... this weekend we will go for DICE :eek:
DrMrLordX
23,233
13,325
Wish I had ambients like that. If I let it get that cold in here the wife would kill me . . .
Good luck!
What's the 1M time @5.3 GHz?
I'd actually like to see the 1M and 32M times on that OC. I remember seeing locked multi Clarkdales struggle with 32M due to limited memory bandwidth/high latency thanks to the IMC wigging out at a high BCLK. With a lower BCLK, they might be able to get some decent memory bandwidth and latency going. Maybe.
Martimus
4,490
157
That is the first time I have heard someone wish the weather was freezing. At those temperatures, you couldn't even go skiing or snow boarding, because it is slightly above the freezing point. I for one am happy that I won't see that kind of weather for another 4 months, even if my electric bill is rather high paying for the AC.
Does anyone build a little ledge outside their window to place there computer during the winter? I couldn't see just turning off your heat, since your pipes would burst, and wearing a full winter coat all day probably wouldn't be enough to avoid frost bite.
Anubis
78,712
427
tbqhwy.com
que, you sure as shit can go skiing when its 0-3C out
clockero-ut
hahaha funny post friends :p
Santiago it's a f*cking DRY and COLD city.. no rain, no snow :( the lowest temps are about 7~8 AM..
again, thanks for your posting :)
Cheers
DrMrLordX
23,233
13,325
Just because I want my computer's ambients to be that low doesn't mean that I want the weather to be that cold. Cold weather is probably the cheapest and easiest way to achieve such ambients, though.
clockero-ut
hey guys.. We come back again with the final results..
before SS, the complete entry in our page is
OK, I warned you before, now you have an infraction. No links to your website are allowed in your post.
Markfw900
Anandtech Moderator
Hardware used:
980x ES powered By Intel and PC Factory
655k and 875k both ES powered by Intel and PC Factory
930
DFI UT X58
Gigabyte X58A-UD3R
Evga P55 FTW
Gigabyte P55A-UD3P
HD 5970
HD 5870
Ocz Platinum 3x2gb 1800mhz
Ocz Reaper 3x1gb and 3x2gb 1866MHz
PC Power & Cooling 750w
Zalman 850w (heatpipes ed. )
Kingpin F1 Dragon POT
Koolance LN2V2 POT
Noctua NH-D14
Its our first time wiht Koolance, and we can say that its an AMAZING pot, +1 to koolance ;)
First Sp 1m sub 8 in Chile :)
I will continue in next post (image limit to 10 :( )
clockero-ut
6049 GHz on 655k Validation
http://valid.canardpc.com/show_oc.php?id=1240474
Not a good run with 875k
And nacional benchmark with superpi 2M
With more time I'm sure we'll reach sub 18 and probably sub 17 :p
3Dmark 03 :biggrin:
3Dmark 06 no tweaks, 980x on DFI X58 wasn't a good combination, we couldn't set memory divider and uncore :\
We got 338xx but only on validation no SS.
And the WR with 655K ON AIR
Intel 655 K ES + Gigabyte P55A-UD3P + OCZ platinum + Noctua NH-D14
Any suggestion, please tell me =)
Regards from Chile :D
Markfw
May 16, 2002
27,418
16,277
I guess you are not reading my edits above, so one more time !!!
Markfw900
Anandtech Moderator
clockero-ut
oohh im so sorry :S
I was so crazy with the result that not knew that rule... forvige me please, and my team...
the link will be retirated now :D
Regards ;)
