A friend of mine intended to upgrade her old HP Pavilion, but really built a new system with:
new case (Asus desktop case),
Asus P4B mobo,
P4 1.6Ghz,
256 MB RAM,
GeForce MX 420
reusing from the HP:
11GB HD,
CD-RW,
modem/sound combo card,
ethernet card,
monitor,
speakers,
multimedia keyboard.
Here is the list of problems she's having:
1. On-board sound not working properly.
- The speakers have to be turned up full blast to hear even a whisper. (They are not powered speakers; perhaps the on-board sound requires powered speakers?)
2. Video is messed up after installing the on-board sound drivers.
- Will try to reinstall video drivers to see if that helps. Since installing the on-board sound drivers, the screen no longer changes resolutions properly, images in 640x480 appear in the upper left corner instead of being resized to fill the screen. (Odd that the sound drivers would affect video.)
3. A number of registry errors appear during startup, related to the network card (no on-board NIC).
- Not knowing the exact HP ethernet card used in the original system, we took a guess and eventually got it to work, but can't get rid of the registry error boot messages. I've had this problem before, where adding a network card asks for the original W98 CD, it says it can't find the drivers, but eventually works anyway. /shrug
Anyone experience similar problems? Is it a mobo issue? Or a bad combo of OEM parts with the HP parts?
Asus P4B mobo,
P4 1.6Ghz,
256 MB RAM,
GeForce MX 420
11GB HD,
CD-RW,
ethernet card,
monitor,
speakers,
