- Jan 12, 2005
- 1,354
- 29
- 91
Another one of my friends called to come an look to see what was wrong with his computer. It is a home built computer built in July of 07.
Here is the problem. I went and checked it out and this is what happened. I turned it on and just played around for a while and it worked fine. It ran smoothly, had good speed and looked just fine. I started doing some more things and opened up a couple browsers. I then went and turned on media player when the browsers were on and started listening to music. The screen got a little fuzzy and all the words and pictures etc went multi colored and the machine froze. The one thing I noticed though was that the speakers had some tat tat tat tat sounds continuously coming out of the speakers. I forced shut down and and restarted and tried the same things to have the same result. I know it is not media player that caused this to happen because media player was not opened when it happened to him. He just had several tabs and apps open at the time.
Video card going bad? PSU? CPU? Memory?
These are the components of the machine.
Ultra Black Case w/450 Antec Smartpower power supply
GIGABYTE GA-M57SLI-S4 Socket AM2
NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
2 - Seagate Barracuda ES ST3320620NS 320GB
7200 RPM SATA 3.0Gb/s Hard Drive
AMD Athlon 64 X2 4600+ Windsor 2.4GHz
Socket AM2 Processor Model ADA4600CUBOX
Rosewill RCR-FD200 All-in-one USB 2.0 Black
3.5" Card Reader with 1.44MB Floppy Drive
Logitech 967692-0403 Beige & Black USB + PS/2 RF
Wireless Ergonomics Desktop Comfort Laser Mouse Included
LITE-ON Black SATA DVD-ROM Drive Model SHD-16S1S-05
Sony NEC Optiarc 18X DVD±R DVD Burner with
12X DVD-RAM Write Black SATA Model AD-7170S-0B
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM
DDR2 800 (PC2 6400) Dual Memory Model TWIN2X2048-6400
XFX GeForce 8500 GT 256MB PCI Express Video Card w/DVI
It is raid 1 and one of the hdd went down a couple of months ago that I replaced for him.
