VirtualLarry
Last night, my friend was having some "internet / computer issues". So he swapped out his main PC, and hooked up his backup PC, but he's still having the same issues. (Which, to me, indicates that the problem clearly isn't the computer.)
He's borrowing internet from a neighbor two floors up in his apt building, with a high-powered client N150 Wifi adapter.
Current issues (with main PC), includes, Windows Update stalling during the "Download" phase, MagicJack not working. (I can hear him, so his upstream is working, but he can't hear me, so his downstream is an issue.)
After hooking up the backup PC, he can't sign in to Skype for some reason,. and MagicJack still has issues.
I tried telling him that his issue was "internet related" (Wifi issues), but since his taskbar shows full bars on his Wifi adapter, he won't listen to me and tells me his internet is fine. Even though MagicJack has the severe issues, along with everything else going on.
Am I wrong? I always try to do speed tests and test the actual throughput of a Wifi connection, and generally don't pay attention to how many bars it shows.
I tried hooking up a high-powered Wifi router to a relative's internet here, and then I used a 9dbi N300 high-powered Wifi adapter to try to connect to it. It showed nearly full bars, and I could see it, and apparently, authenticate, but I couldn't get internet through it. I'm guessing, that I couldn't send enough signal upstream back to the router.
Anyways, my friend's neighbor upstairs isn't using any sort of specific high-power router, so I was thinking of trying to hook one up as a secondary router. At least, that would be my technical solution, or attempt at a solution, but now I'm thinking, I really don't want to be on the hook every time his internet burps.
So, I'm thinking of finally punting my friend to Geek Squad to solve his problems. (I have no idea what they would recommend - probably the most expensive router and client wifi that BestBuy sells. Might work, might not.) Or maybe they wouldn't want to get involved in sharing internet either.
I told my friend a month ago to sign up for the $10/mo internet via a Sprint LTE MiFi, but he wasn't interested, he considered his existing internet-sharing situation to be superior, so he wouldn't even consider getting his "own" internet.
Any suggestions? My friend was kinda pissed at me for not coming out and "fixing" his internet, before he went to work today a few hours later, and that I didn't want to go over to his place and "fix" it after he got out of work.
