- Oct 9, 2002
- 28,298
- 1,235
- 136
I recently purchased an eVGA/NVIDIA NVTV dual tuner card for use in my MCE2005 rig. It fried shortly after I had everything set up, even though it was running through a brand-new surge supressor of decent quality (with a grounding indicator, probably relating to the electrical socket) and there had been no bad weather. When I touch the coaxial connector and the case chassis at the same time, I can feel an uncomfortable amount of electricity flowing through me and shocking me each time my tender arm gets near the chassis. :Q
Do surge supressors use the ground from the electrical socket for the coaxial cable? It would make sense.
As a cable Internet installer for a different cable company, I went out to the box on the side of my house to have a look and saw that the splitwork was not grounded. The cable technician looked at the utility pole where the wire is coming from and says that the cable is grounded there. How can I tell if the ground is actually working? If it is, shouldn't the charge be equal to that of my electrical ground, causing little or no electricity to flow when I touch the chassis?
