Freaking greek tragedy!!!
I had a Soyo Dragon K7V plus with a XP 1900 OC's to 1.74. Decent OC however not great considering I have a MCX462 on top of it.
I read a few good reviews about the Shuttle AK35 with numerous voltage tweaks. Vcore adjustments to 2.3volts had my name all over it. I figured with a little extra juice (1.95 or so) and I should be able to get a 1.8 OC.
Received the board yesterday. Took it into the office today to exchange mainboards with a friend of mine. Immediately, I noticed that the four holes around the socket are smaller than the soyo. This sucked because the sleeve washer did not fully insert into the holes. Not only that, f**king shuttle decided to place smaller transitors right up against the holes. So, not only do you not have grounded holes like MB mounts but the holes are not even large enough to accomodate the sleeve washers that swiftech recommend you use. You can't place metal standoffs on traces. Not a good idea. Unfortunately no red flags were raising.
The tragic thing is I hadn't noticed that the sleeve washers weren't properly seated because of the small holes on this goddamn mainboard. Little did I realize there was a millimeter air gap between the core and the heatsink after I screwed it down on the standoffs. Incidently the northbridge heatsink pin also is too close to the socket and these large heatsinks overlap them. That's crap also!
Well, I installed all my cards, hooked all the cable up, shook everyone's hands, patted myself on the back and proceeded to turn on the power. .......nothing but black screen which seemed like an eternity. My friend said he smelled something and immediately jerked the power cable. Argh!!!!!!!!!!!!!!!!!!!!!!!! too late!!!!!!!!!!!!!!!
Utter quiet had befallen us as we stared at each other! You could hear a pin drop before I screamed and cried in horror. Only a family member suffering such a fate would have made me feel worse.
We removed the MB and soon discovered the design flaw of this f**king board. We removed the heatsink and there it was... a small light brown soot mark on the artic silver compound. Core looked great though. Not a mark on it. Athlon XP thermal protection is a f**king OXYMORON that AMD has perpetrated on us unsuspecting few. Ha! I wanted to scratch my eyes out. It certainly would have been less painful!
EVERYONE BE FOREWARNED! DO NOT BUY A SHUTTLE AK35 IF YOU WANT TO INSTALL A MCX462 OR PAL 8045! You will cetainly F**k yourself up the back side.
I broke the news to my wife earlier today. She expressed sympathy however I'm certain she did not fully understand my grief. She did later on today call to see how I was feeling and indicated that I could order a new CPU. She truly is blessed!
As I was writing about my tragedy tonight my wife asked me if we were going to have a memorial service this weekend? She asked me if she needed to prepare some snacks and drinks for funeral reception. She's such a dear!
Newegg must love me!
