Originally posted by: Strangone
It's not something I'd fret about. OH!
I'm here all week, folks. Try the veal.
Seriously, it's supposed to help sustain + better tone (due to better strings and pickups). They're supposed to be harder to play tho, at least as far as finding exactly where you want to be on the neck (the majority have locator dots, tho).
gah, misinformation!
a fretless bass does not use different strings or pickups than a standard bass unless you want it to. since many fretless basses are high-end models (beginners don't want them), yes, they tend to have nice pickups, but any high-end bass will have nice pickups. on both kinds you can use any strings or pickups you want.
sustain is worse because your finger does not provide a solid end for the string. the soft part of your finger will always touch the string and mute it slightly. this will also result in a "softer," less percussive tone. fretless basses are harder to play because, like a violin/viola/cello/double-bass, you must place your finger perfectly to sound the correct pitch, and you must remember the placement on your own. some fretless basses have inlaid lines to tell you where to put your finger, but many don't. you have to go by sheer feel. with a fretted instrument, you can place your finger nearly anywhere between the frets to sound the pitch you want, so there's a lot more "wiggle" room.
the advantages? some people like the muted tone, and you can slide between notes with an infinite variety of pitches, as opposed to stepped intervals like a fretted bass. you can also use vibrato in a different way by rolling your finger around as opposed to having to yank the string like on a fretted instrument. they're basically used for jazz, fusion, and pop music. they don't have much place in rock because the tone doesn't cut.
Originally posted by: plastick
I am going to buy a new bass sometime here...I've heard about fretless bass guitars and I was wondering whats the difference? (aside from the frets) Are they easier to play? hearder? Do they sound different? What are they ideal for?
thanks
