I watched on lastnight on the laptop and it also seemed to repeat the problem.does it stutter if you just play it on the laptop?
Try VLC, its free and is capable.
Thank you.
Aside from it installing a yahoo toolbar, it was perfect.
It worked, and there are no more stutters.
Thank you.
uninstall it asap.
the toobar.Oh noes?
Uninstall the app or just the add-ons?
Anyway, the freezing came back.
Is the only solution a new and faster laptop?
the toobar.
quick question, were you playing off the battery? some laptop cut your computer's performance when you are on battery.
what exactly is the source? normal avi files should not stump your laptop.
can you run cpu-z and post the cpu and video card info?
http://www.cpuid.com/softwares/cpu-z.html
720p MKV is the file type
Intel Mobile Core 2 Duo T6500
Windows 7 Home Premium Edition (Build 7600)
CPU Arch : 1 CPU - 2 Cores - 2 Threads
CPU PSN : Intel Core2 Duo CPU T6500 @ 2.10GHz
CPU EXT : MMX, SSE (1, 2, 3, 3S, 4.1), EM64T
CPUID : 6.7.A / Extended : 6.17
CPU Cache : L1 : 2 x 32 / 2 x 32 KB - L2 : 2048 KB
Core : Penryn (45 nm) / Stepping : R0
Freq : 1196.55 MHz (199.42 * 6)
MB Brand : Dell
MB Model : 0D176M
NB : Intel GM45/GM47 rev 07
SB : Intel 82801IM (ICH9-M) rev 03
GPU Type : Mobile Intel(R) 4 Series Express Chipset Family
DirectX Version : 11.0
RAM : 4096 MB DDR2 Dual Channel
RAM Speed : 398.8 MHz (1:2) @ 6-6-6-18
Slot 1 : 2048MB (6400)
Slot 1 Manufacturer : Hyundai Electronics
Slot 2 : 2048MB (6400)
Slot 2 Manufacturer : Hyundai Electronics
Great news!There is no reason whatsoever why your 720p video should stutter at all from that hardware.
I think they are updated.Have you tried updating the video driver?
All my files do this.All MKVs do this or just one file?
Do you mean ask the question there?You can also try http://mpc-hc.sourceforge.net//
uninstall divx player.
No. I shall try that now.also, did you try just windows media player?
Great news!
I just installed the VLC and I just updated the DivX
Will that allow the VLC player to run better?
