Freezer 7 Pro install
cmt9000
43
I am about to install a Freezer 7 Pro, but noticed that no thermal grease is included.
Can I just install it as is on a Core 2 Duo CPU?
Do I need to clean anything off?
Thanks
CalvinHobbes
3,524
Isn't there something already on the base of the cooler. My freezer pro already had something applied.
If your's doesn't for some reason I would suggest putting some on.
cmt9000
43
It does, but I was wondering if I should buy some stuff like Artic Silver 5....it has a ton of positive reviews on newegg
avi85
988
AC ships their heatsinks with pre-applied MX-1 which is supposed to be as good as, if not better than AS5
RallyMaster
5,581
MX-1 works better than AS5 on Freezer 64/7 Pro heatsinks. I can tell you this from experience...
cmt9000
43
Oh ok...so I just need to take off the stock CPU heatsink/cooler and clean the top of the Intel E6600?
