Freezer 7 pro...how do I install it?
asintu
1. Does the orientation in which i install it matter? I'm asking cause i might not have room to install it certain ways. What's the optimal orientation?
2. What's the order of installing the pushpins? Anyone, diagonal, and then same with the rest of two? Is that good? Do i have to push 2 pins at the same time or one at a time?
1. Optimal is the fan blowing towards your back exhaust.
2. Did you read the install manual?...
Originally posted by: RallyMaster
It's blowing into the heatsink.
would it be bad to orient the cooler such that the fan takes some hot air surrounding the NB and blowing it into the heatsink upwards towards the power supply?
