Freeware solution: Data-recovery
THESANTINI
66
I formatted my HDD Saturday. Lost data that I now need to recover after a quick NFTS format. Is there any software that will allow me to recover?
OCedHrt
613
If it's just a format and you did not write anything to the drive, all your data should be easily recoverable. More likely than not you may even be able to restore the entire partition. That would be where I'd start unless you're only looking for a few files.
Give this a try:
http://www.cgsecurity.org/wiki/TestDisk
