Freeware programs and applications (continuation)
Page 13 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Blazer7
1,136
12
Partition manager tool : Easeus Partition Manager 3.0. Easeus partition manager is very much alike Partition Magic. Note that only the home edition is free.
PDF Creator : PDF reDirect v2.2.8. Freeware PDF printer.
*** More on VNC ***
Most VNC derivatives use more or less the same service. This allows different VNC viewers to connect to PCs that run ?different? VNC server services. For example if a PC is running real VNC server one can still use Ultra VNC's viewer to connect. That works the other way around too. Currently real VNC does not support Vista but Ultra VNC does. One can gain access to a Vista machine using Real VNC's viewer provided that the Vista machine runs Ultra VNC's server.
jmcb
32
Im trying to add stuff not already here. I use most of whats posted. So many good freeware appz.
CPU-Z - gets info about devices on your system.
gba
833
Defraggler can defragment individual files, groups of files, or free space on any FAT32 or NTFS partition. It also displays the location of these files on the specified partition. Defraggler is also a portable program that can be used from a USB flash drive.
Defraggler runs on Microsoft Windows; it has support for all versions since Windows 2000. It includes support for both 32- and 64-bit versions of these operating systems.
Wheezer
6,731
Install it
Windows only: Free app Install-It puts a small auto-starting application on any removable drive that makes installing applications a double-click affair.
After downloading the Install-It package, you'll want to extract its files to somewhere you can reach, like your desktop, and open up the Install.ini file in your favorite text editor. This file is simply a list of program descriptions and the locations of their installer files. If you're creating a disc full of useful installers, just replace the default examples with your chosen verbiage for each app and the location/names of the setup files. You separate those two items with a comma, using slashes where necessary, and end each line with a semi-colon.
will889
1,463
A few more free tools I use
MsconfigCleanup
*This utility is handy when apps like to put themselves in startup and you then take them out of startup -- this tool cleans up the orphaned entries from startup in msconfig.
MOveOnBoot
*Gets rid of stubborn files that will not delete fully.
moonbit
640
Anybody know of any personal finance freeware that works like a stripped-down version of Quicken? I just really want the register, account reconciliation feature, and the ability to run very simple reports. (Yes I know about Quicken Online, but I'm old-fashioned and don't know how I feel about having my financial information stored somewhere other than on my own computer.)
lucasorion
236
any of these look appealing? :
http://zenhabits.net/2007/05/6...s-to-quicken-ms-money/
dwell
pics?
Don't know if it's been mentioned in this thread (search is broken) but CloneZilla is a great free alternative to Norton Ghost. It does what the old Ghost would do in imaging and copying partitions offline from a boot disk.
JimKiler
3,559
205
Audio conversion
dbPowerAmp - Suggested by xgi.
foobar2000 - Great for playback and really easy conversions between audio formats (just make sure to install all the output plug-ins that you want).
to stay current please add iTunes to this list.
JimKiler
3,559
205
thanks, that is what i needed and what brought me to this thread. I will have to check it out. i want to reinstall Win7 beta but when I tried it before it hung and I was never able to reboot WinXP until I did a new install, I want to avoid that again.
Demitre
83
Is there a freeware that will scan a disk drive and provide a report of spaced used per directory, per age of last modified, etc?
All in an easy report that can be sent to others or saved for later viewing?
hasu
993
10
Try WinDirStat.
I am not sure if it has all the features you asked for.
Elias824
1,100
no cpu-z? speed fan? orthos? prime 95? oh ultramon is a awesome program for dual using dual screens. Also maybe include some HDD image/backups software on the list. Other then that great, I use a ton of those programs already
TungFree
1,619
I need a free password recovery program.
to get into my hard drive with xp given to my by my late auntie.
