I noticed an improvement in sound quality even on my DTT2500 speakers. However, some songs end up sounding pretty bad because of the algorithm that they use. I haven't used it in a long time so I can't remember exactly what the problem is.
[edit] Ok I just reread that old thread, and WOWthing is worse then I remember. It is a POS, STAY AWAY unless you have REALLY CRAPPY speakers [/edit]
If you install this, and then don't want to run it, make sure you DON"T JUST TURN it off. You need to remove the plugin. When you just turn it off, it makes everything sound like crap, when you remove the plugin, you notice that it's almost the same as before.
WowThing is more of a gimmick then anything else.
I give this
1/2 a star out of 10.
The loudness button on stereos adds the proximity effect to the music. When you listen to music softly you loose a lot of the bass and some mids. The loudness button increases the bass and the highs. Try it before bashing someone.
For any other questions, look up the Fletcher Munson Curve...
