- May 17, 2008
- 10,004
- 63
- 91
A pump does not necessarily translate to functional strength. I can pump my calves all day but it's not going to help my deadlift more than heavy reps of deads. Similarly, you're not going to need huge heads on all 3 parts of the tri's to bench 350, they will grow as the needed resistance increases. While it's good to do accessory work, be sure that you're efficient with your time for your goals. For example, I'm not going to do cable rows when I can do barbell rows which translates to the deadlift a helluva lot more. If I'm bodybuilding, then maybe I would do lighter weight cable rows to work on a weakness.
Regarding the EZ bar, you can do that on a normal bench (doesn't have to be on a decline) since you're not locking it out. It's short half movement nose breaker/close grip BP where your biceps/forearms can slow the momentum and take some pressure off the elbows. Try some lighter weight to get the movement down before going heavy. As for regular decline overload, it's effective for tri's because it's taking some regular delt/pectoral recruitment out of the movement which will activate the tri's more. Another thing I'll do (if I don't have weights) is to do many pushups with a slingshot, which forces your triceps to work much harder since it takes a good deal of delt out of the movement.
Well, let's be clear- I'm not looking to be a power lifter. I've seen the "power lifters" in my gym. They are either kind of just... fat and bulky but really strong, or pretty much normal looking, not lean at all, but still pretty strong (for their weight).
I would rather bench 225 and look great, than 315, but look like everybody else. I'm not going to powerlift in any comps, and I'm not a pro athlete, so my idea of functional strength probably isn't the same as yours. If I can join the double body weight DL club, that would be a cool goal to meet, but I won't beat myself up if I can't.
I'm pretty aware that I will get "more bang for my buck" doing compound, free weight stuff. That's always my priority. Something like shrugs or farmers walks, can never be done or replicated well on a machine, so I will always do those for my traps. Lately though, because of wrist pain for example, I've really kind of gravitated toward machines for tricep stuff. I can use bars which put me in less of a pronated position, which just feels better. Although I am going to experiment with the EZ curl bar tomorrow.
For the record, today was shoulder day, and everything was free weight. Still got a good pump in.
