Free Ring Tones~!!! Right click and Save POLYPHONIC
isekii
28,578
Originally posted by: deejayshakur
not a bad post, but most of these come with the newer SE phones.
yes i know I got em from the Sony site.
There are some that aren't on the SE phones tho.
I took those off the t610 and these work with T300, and any other SE phones that support polyphonic.
I'm pretty sure these will work with other providers as well.
I use infrared to transfer them over, i guess you can use data cable.
isekii
28,578
Originally posted by: willboxer
you should clarify that these are for specific phones
the other guys nokia probably isn't polyphonic.
it aint my fault ancient pos nokia doesn't offer polyphonic
isekii
28,578
Originally posted by: weepul
um. i thought ringtones had to be converted to something other than midi...
//krunk (^_^x)
I think it needs to converted to something that is smaller file size than a standard midi file.
these files are less than 10kb
Average like 5-6kb
Jonnses
21
i have a motorola t722i and i also bought the usb cable kit along with it. anyone know how i can dl mid's to my computer and transfer it over to my phone? i couldn't find any website stating instruction as to how. any help is appreciated.
thanks,
jonz
terthen
374
many of nokia's newer phones (7210, 6610, 6100, 6200, etc) require you to use their Nokia PC Suite to upload photos and images; just load the MIDI in the PC Suite's ringtone convertor.
Some of Samsung's (S105) required it to be converted to MMF, psmplay can do this for you.
t720 requires you to download it via WAP, so t722i might require this too.
Siemens and SE can play the midi's directly.
kellybrf
167
Originally posted by: TheToOTaLL
I sure wish Nextel has Polyphonic phones :(
hahahahahahahahaha!!! nextel will be dead in a few years, dont get your hopes up of any cool phones
ebaycj
5,418
the i95cl and the i90c do. ColdCircle
They also (unsupported) allow uploading to your phone from your computer.
and to YOU, A$$HOLE:
1.) have you seen the new i730? its tiny. and has a hi-res color screen.
2.) nextel is tied with verizon for best coverage.
3.) why do you think verizon is now imitating nextel's direct connect? imitation is the greatest form of flattery.
ebaycj
Fritzo
41,920
2,161
They play on my Nokia 3650 fine. Luv the cartoon one :D
I usually do wav files for my ringtones though. For instance, when my wife calls, I have a godzilla.wav that goes off.
