Free Basic Oil Analysis Test Kit
dyn2nvu
631
http://www.polarislabs1.com/test-kit.htm
The POLARIS Promise: Fast · Accurate · Reliable
Test us and see for yourself how fast, accurate results can affect your maintenance practices.
The value of fluid analysis results diminishes significantly with time as the condition of both the fluid and the equipment being tested continue to change. As a result, turnaround time is often the number one priority when it comes to choosing a testing facility. POLARIS Laboratories offers fast, accurate and reliable testing. It's the Polaris Promise. Learn more about the importance of Turnaround Time.
Complete the form below for your free Basic Oil Analysis Test Kit**:
**For new customers only. Kits will only be sent to addresses within the continental United States, Canada, Mexico, Alaska, Hawaii and Puerto Rico. Limit one free test kit per person / company.
BigBadMunky
102
Cool...I've been curious as to how comprehensive these tests are. Good way to show how much further then the 3k/3mnth recommendation while still keeping the engine safe.
DurocShark
15,708
56
Keep in mind that any analysis is only valuable as a trending tool. Your oil conditions literally change from minute to minute.
But, yes, it will give you an idea of how broken down your oil is. But "shearing" isn't the only way to lose lubrication from the oil. Contaminants blow in and out of your crankcase as you drive. Dirt gets filtered out. You get the idea.
jburnham
85
I've always used Blackstone Labs http://www.blackstone-labs.com/
They'll always send you free collection kits and only charge you when you send them in. They email a PDF and mail hardcopy - and keep your history and give a nice summary expert opinion.
I usually keep my cars 10+ years and am less interested in extending my drain intervals than in knowing when things are going bad.
Coraanu
1,112
Thanks, OP, for the deal and another bump for Blackstone. I've got my oil drain interval up to about 6,000 mi on a VQ35DE engine running Mobil1 5W30.
jburnham
85
Bump for the VQ35DE second only to the SR20DE. Too bad mine is still showing high lead - might be premature bearing wear.
Whatcha got Coraanu? G35 Coupe 6MT?
